Docs about the data passed to event listeners in the ArcGIS Pro SDK
799
12-07-2020 02:27 PM
MikeDavlantes
New Contributor III
I come from a background of web development and am having difficulty making sense of the ArcGIS Pro SDK API reference. I see that there’s a class for a LayersAdded event (docs herebut how do I see what data will be in the event? This exists in my code, and it works:
LayersAddedEvent.Subscribe((evt) => ...do something with event);
but in order to see what properties the event has, I have been triggering an event and logging it. This does not seem like the right way of doing things, but I am a lowly web developer who doesn’t really understand fully how C# or the Pro SDK API reference works. I'm trying to handle many different events. How can I tell what is getting returned?
Wolf
by Esri Regular Contributor
Hi Mike,
 The ArcGIS Pro SDK wiki explains how to 'subscribe' to Pro Events using the Pro SDK in general: ProConcepts Framework Events Specifically when you subscribe to an LayerAddedEvent you have to look at the parameter required for the Subscribe method (API Reference) :
public static SubscriptionToken Subscribe(
   Action<LayerEventsArgs> action,
   bool keepSubscriberAlive
The parameter Action<LayerEventsArgs> indicates that you have to specify a 'delegate' (action method) here.  The delegate action method has one parameter LayerEventsArgs and looking at the members of LayerEventsArgs you will notice that it contains a Layers property which contains the layers (as an enumeration)  that are added.  To test this i created an add-in module with a single button.  The OnClick method for the button contains this test code:
protected override void OnClick()
	LayersAddedEvent.Subscribe((evtArgs) =>
		System.Diagnostics.Debug.WriteLine("LayersAddedEvent");
		foreach (var lyr in evtArgs.Layers)
			System.Diagnostics.Debug.WriteLine($@"Added this layer: {lyr.Name}");
To test this i click my button and then add a new layer to my map view and I get the following output in my Visual Studio output window:
LayersAddedEvent
Added this layer: TestMultiPoints
Wolf
Hi Mike,
LayersAddedEvent
MikeDavlantes
New Contributor III
Thanks Wolf-- this was very helpful! Looking at it now I think most of my difficulty was just in navigating the docs. Getting from the `LayersAdded` page to `LayerEventsArgs` isn't particularly straightforward.
Wolf
You are correct that "Getting from the `LayersAdded` page to `LayerEventsArgs` isn't straightforward".  We had this issue in our cross hairs for a while, it's a limitation in the third party software we are using for the API reference website generation.  We are hoping to fix this 'linkage' problem in one of the upcoming releases.
