Dear Team,
Could you Please help me with some documentation and steps on how to Deployment of an Addin in ArcGIS Pro in the client machine.
Thanking you in advance.
Hello Kaiser,
I was able to solve that issue...As I have created a Pro Configured Module...I was able to get the Deployment by creating a shortcut.
My issue was I would like to Create a Setup or Windows Installer Package for my solution. So that the Client who is having ArcGIS Pro Installed on their machines should be able to use my addin after running the setup.
Example: XTools.....When you download XTools for ArcGIS Pro...They will give us a Windows Installer Package and when we run that Package addins will be installed to the respective folders and we will start working directly on the Tools.
This is how I would like to Package my solution.
Ok I see what you're trying to do now. In general the SDK distinguishes between add-ins and [managed] configurations, therefore we have also two different project templates for both options (one for add-ins and one for managed configurations).
So yes if you like a give your users a 'turn-key' experience for a 'managed configuration' (option 2 above) then a setup or windows installer is needed to copy the configuration package, and then create a shortcut or define the required registry key.
I had a follow up question to this, I have developed an add in and it works fine on my machine. I am having trouble deploying it to a client machine. I have figured out how to change the version from 2.7 to 2.5 and the add installs successfully. However, the add in buttons grey out when they are clicked and so not respond. Is there a setting in the configuration/deployment that I am missing? or does the client machine need to have .net framework 4.8 installed?
@AndersBerg1 Did you ever figure this out? I'm experiencing the same issue.
I suspect that the client machine does need the target .net framework installed, but I'm not sure about that.
EDIT: this gets answered in his followup question.
