creating balloon callout on graphics layer
6388
12
10-26-2021 09:06 AM
LeLuong
All,
Has anyone successfully created a balloon callout on graphics layer by codes ?  I asked this question before with previous version of arcgis Pro.  I was under the impression with version 2.8 I should be able to do it but no luck so far.  Below is my codes.  I got all other properties correct but NO callout arrow.   Thanks in advance for your help.
Not a calloutNot a callout
 _subjectTextSymbol = await CreateBalloonCalloutAsync(ColorFactory.Instance.RedRGB);
 subjectLabelGraphic.Text = "Subject";
                            subjectLabelGraphic.Symbol = _subjectTextSymbol.MakeSymbolReference();
                            //Add the graphic label
                            graphicsLayer.AddElement(subjectLabelGraphic);
private static Task<CIMTextSymbol> CreateBalloonCalloutAsync(CIMColor textColor)
            return QueuedTask.Run<CIMTextSymbol>(() =>
                //create a text symbol
                var textSymbol = SymbolFactory.Instance.ConstructTextSymbol(textColor, 11, "Corbel", "Regular");
                //A balloon callout
                var balloonCallout = new CIMBalloonCallout();
                //set the callout's style
                balloonCallout.BalloonStyle = BalloonCalloutStyle.RoundedRectangle;
                //Create a solid fill polygon symbol for the callout.
                var polySymbol = SymbolFactory.Instance.ConstructPolygonSymbol(ColorFactory.Instance.GreyRGB, SimpleFillStyle.Solid);
                //Set the callout's background to be the black polygon symbol
                balloonCallout.BackgroundSymbol = polySymbol;
                //margin inside the callout to place the text
                balloonCallout.Margin = new CIMTextMargin
                    Left = 5,
                    Right = 5,
                    Bottom = 5,
                    Top = 5
                //assign the callout to the text symbol's callout property
                textSymbol.Callout = balloonCallout;
                return textSymbol;
JeremyWiles
Thanks for the reply @LeLuong.  That is very interesting that it is possible through the SDK but on the UI.  Also that it allows that in the first place.
I can only hope that these types of features that are not available in the UI will be available in the SDK in the future.
LeLuong
Yayyyy! I got it.  Thank yo very much @CharlesMacleod .
CharlesMacleod
to coin a phrase: just do it. this is possible through the api and, apparently, not the ui.
var textGraphic = new CIMTextGraphic() {
  Text = "Callout Text",
  Placement = Anchor.CenterPoint,
  Symbol = textSymbol.MakeSymbolReference(),
  Shape = MapView.Active.Extent.Center,
  //Leaders is an array of CIMLeader - add a Leader point to show
  //the leader, remove Leaders to hide the leader.
  Leaders = new CIMLeader[] {
    new CIMLeaderPoint(){
      Point = MapPointBuilderEx.CreateMapPoint(
          MapView.Active.Extent.Center.X - 5000,
          MapView.Active.Extent.Center.Y - 1500)
          MapView.Active.Extent.Center.X - 3500,
          MapView.Active.Extent.Center.Y - 2500)
          MapView.Active.Extent.Center.X - 500,
          MapView.Active.Extent.Center.Y - 5000)
