Can I retrieve a list of tags used in ArcGIS Portal, and search after PortalItems based on tags?
226
03-24-2022 10:19 AM
TomGeo
Occasional Contributor III
I am wondering if it is possible with the ArcGIS Pro SDK to retrieve a collection of tags used in an ArcGIS Enterprise Portal. Using the web interface of a portal I can do this basically at every corner.
However, I could not find a way to get tags used on portal content, and I missed the way to query the portal for content by way of tags.
It seems as there is the possibility to retrieve the collection of tags when using Python (https://support.esri.com/en/technical-article/000020473), but in C#...
- We are living in the 21st century.
GIS moved on and nobody needs a format consisting out of at least three files! No, nobody needs shapefiles, not even for the sake of an exchange format. Folks, use GeoPackage to exchange data with other GIS!
GintautasKmieliauskas
Regular Contributor II
There are sharing snippets for ArcGIS Pro SDK: https://github.com/Esri/arcgis-pro-sdk/wiki/ProSnippets-sharing.
I think "Portal: Execute a portal search" could be useful for your task,
TomGeo
I even have this page bookmarked... 😉
Well, kudos to you, it works fine. I was just not expecting that there is no dedicated PortalQueryParameters method to aim at tags.
