Can I access the vertices selected in vertex editing?
711
09-19-2023 01:11 AM
ViktorSafar
I have a custom pane with a VM behind it, and at some point it starts vertex editing of the currently selected feature via
var editCommand = FrameworkApplication.GetPlugInWrapper("esri_editing_EditVerticesNormal") as ICommand;
if (editCommand != null && editCommand.CanExecute(null))
    editCommand.Execute(null);
In this state it is possible to select vertices of the geometry, either by lasso or by clicking them in the list in the Modify Features pane. Can I access this selection?
AyanPalit
@ViktorSafar Vertices can be selected when using the Edit Vertices tool in ArcGIS Pro.
I have not tested this programmatically.
Ayan Palit | Principal Consultant Esri
