Call Geoprocessing.ExecuteToolAsync on managment.CreateTable is failing
3779
6
07-09-2020 08:00 AM
MarcusPolivirus
Based on this example L. 90, I'm trying to create a FeatureClass in an Oracle database using the geoprocessing tool "managment.CreateTable".
In the documentation it's said that the argument "out_path" should be of type Workspace.
Problem is, in this documentation, it is said that only the following classes are supported :
  • Scalars – long, short, float, double, date, string
  • ArcGIS.Core.Geometry.SpatialReference
  • ArcGIS.Core.Geometry – point, line, polygon
  • ArcGIS.Core.Geometry.Envelope – supporting GP types of GPExtentEnv, GPExtent, GPEneveope
  • ArcGIS.Core.Data.Field – supporting GPField and list of fields for GPFieldList
  • ArcGIS.Desktop.Mapping – Layer, StandaloneTable
  • ArcGIS.Core.Data.Dataset – Table, FeatureClass
Based on those informations I'm using the following code
private static Task<IGPResult> CreateFeatureClass(Geodatabase geodatabase,
string tableName,
Table templateTable)
var args = Geoprocessing.MakeValueArray(
geodatabase.GetConnectionString(),
GetTempoLayerNameFromFClassName(tableName),
templateTable,
null
System.Threading.CancellationTokenSource _cts = new System.Threading.CancellationTokenSource();
return Geoprocessing.ExecuteToolAsync("managment.CreateTable", args, null, _cts.Token,
(event_name, o) => // implement delegate and handle events, o is message object.
switch (event_name)
case "OnValidate": // stop execute if any warnings
if ((o as IGPMessage[]).Any(it => it.Type == GPMessageType.Warning))
_cts.Cancel();
break;
case "OnProgressMessage":
string msg = string.Format("{0}: {1}", new object[] { event_name, (string)o });
System.Diagnostics.Debug.WriteLine(msg);
_cts.Cancel();
break;
case "OnProgressPos":
string msg2 = string.Format("{0}: {1} %", new object[] { event_name, (int)o });
System.Diagnostics.Debug.WriteLine(msg2);
_cts.Cancel();
break;
The results of the request is :
ErrorCode = 2147483647
HasWarnings = False
IsFailed = True
IsCanceled = False
There is no messages whatsoever.
I have no idea how to debug that part.
Do you have any clue ?
Best regards,
Marcus
Tags (1)
RichRuh
Hi Marcus,
I'm not a geoprocessing expert, but I would try this:
geodatabase.GetPath(),
templateTable.GetPath(),
null
--Rich
MarcusPolivirus
Hello Rich,
Thanks for your reply, I tried :
geodatabase.GetPath().AbsolutePath,
templateTable,
null
The class Table has no GetPath method.
The geoprocessing tool shoud use the "templateTable" object as a template for the new Table (create the same fields i think and maybe other things).
Normally it is supported to use a Table.
The method GetTempoLayerNameFromFClassName just return a string.
I end up with the same error :
HasWarnings = False
IsFailed = True
IsCanceled = False
RichRuh
It was worth trying.  Hopefully someone from Geoprocessing‌ can provide a better answer.
Sorry about Table.GetPath(). I had forgotten when we added it- you should see it later this summer in Pro 2.6.
--Rich
RichRuh
In Pro 2.6, GetPath() is now available on tables and other datasets.
NarelleChedzey
Hi Marcus,
I've had success using the following code
IGPResult result = await Geoprocessing.ExecuteToolAsync("CreateTable_management", new string[] {
gdbPath,
tableName
}, null, ctsToken, null, GPExecuteToolFlags.RefreshProjectItems);
Note that this will create an empty table as it is not using a template object.
Right now you're not really sure which of the parameters is the problem, so I would suggest trying with just two parameters first to make sure you can create the empty table (gdbPath and tableName).  Then you are guaranteed to know that the problem is with the third parameter - the table template.   I'm thinking this should be a string too, but am not completely sure.
Note also sing "CreateTable_management" or "management.CreateTable" should not make a difference.
Narelle
MarcusPolivirus
Hi Narelle,
I confirm using your code is working.
It works also with Geoprocessing.MakeValueArray instead of new string[]{}.
Using "management.CreateTable" is not working with your code, the error is:
ReturnValue =
HasWarnings = False
IsFailed = True
IsCanceled = False
In deed, the parameters should be all strings, the following code is working well and create the fields from the template table.
var parameters = Geoprocessing.MakeValueArray(
   tableName,
   System.IO.Path.Combine(templateTable.GetDatastore().GetPath().AbsolutePath, templateTable.GetName())
   parameters,
   null,
   _cts.Token,
   null,
Is there a list somewhere for the geoprocessing tools including: id | name | description | parameters ?
Thanks again for your help Narelle and Rich.
Marcus
