Calculate polygon area and perimeter in geodesic
730
03-04-2021 10:10 PM
PrashantKirpan
After adding polygon I want to calculate area and perimeter in geodesic unit. I'm able to calculate area and convert it into hectares but not sure how to calculate perimeter in kilometer.
Area I'm using below code.
var ft = (Feature)row;
if (ft.GetShape().GeometryType == GeometryType.Polygon)
   var area = GeometryEngine.Instance.GeodesicArea(ft.GetShape()) / 10000;
  //Calculate and convert area from meter to hectares
I couldn't find function to calculate perimeter in GeometryEngine.
Any help would be appreciated.
-Prashant
KirkKuykendall1
Occasional Contributor III
Did you try creating a polyline from segments (see example here) and passing that to GeometryEngine.GeodesicLength ?
ThanHtetAung_EsriAu
Hi @PrashantKirpan ,
Currently there is no option to add unit in the GeometryEngine, mostly are meters by default.
How I solved for that situation at the moment is - divided by 10 ^ 6 or (1000 * 1000) to get square meters.
Similarly for Nautical Miles divided by 1852 ^ 2 or (1862 * 1852) for area value.
Best Regards,
Than
KirkKuykendall1
PrashantKirpan
Thanks for the help. Working fine. Here is my sample code.
ICollection<Segment> collection = new List<Segment>();
poly.GetAllSegments(ref collection);
double lenght = 0;
foreach (var item in collection)
var polyline = new PolylineBuilder(item);
lenght += GeometryEngine.Instance.GeodesicLength(polyline.ToGeometry()) / 1000;
