Building .NET Console Application Using ArcGIS Pro .NET SDK
476
05-22-2020 03:01 AM
AnujKatiyar
I am rewriting ArcObjects .NET Console Application using the Pro SDK. I want to dynamically create / delete shape file in my console application using  Pro SDK but i am not finding any documentation for Pro SDK  for such requirements.
Can you please provide any code sample for same ?
MattDriscoll1
You will need to use geoprocessing tools probably.
Run a geoprocessing task and python script | ArcGIS for Developers
I personally use python to do these types of task.  If I want a gui aspect to it I will just put the python script in the solution and run it from there.
public async Task<IGPResult> ExecuteModel()
var progDlg = new ProgressDialog("Running Geoprocessing Tool", "Cancel");
progDlg.Show();
var progSrc = new CancelableProgressorSource(progDlg);
var pathPython = System.IO.Path.GetDirectoryName((new
System.Uri(Assembly.GetExecutingAssembly().CodeBase)).AbsolutePath);
pathPython = Uri.UnescapeDataString(pathPython);
System.Diagnostics.Debug.WriteLine(pathPython);
var tool_path = System.IO.Path.Combine(pathPython, @"PytonToolbox.pyt\Tool");
var parameters = Geoprocessing.MakeValueArray();
IGPResult gp_result = await Geoprocessing.ExecuteToolAsync(tool_path,
parameters, null, new CancelableProgressorSource(progDlg).Progressor);
Geoprocessing.ShowMessageBox(gp_result.Messages, tool_path,
gp_result.IsFailed ? GPMessageBoxStyle.Error : GPMessageBoxStyle.Default);
return gp_result;
RichRuh
Anuj,
Matt is correct.  The Pro SDK does not yet support Data Definition Language (DDL) operations directly.  If you are writing a Pro Add-in, you need to use the geoprocessing API.  In a stand-alone CoreHost application, you need to shell out to a Python script.
--Rich
AnujKatiyar
Thanks Rich,  Can we use ArcObjects .NET SDK &  Pro SDK together in a CoreHost application ?
RichRuh
Anuj,
The Pro SDK is implemented in terms of ArcObjects.  While I've never tried it personally, I expect the two APIs would interfere with each other.  It's definitely not supported.
--Rich
