ArcGIS Pro SDK support for linear referencing?
1667
10
10-10-2018 02:35 PM
daleward
Does the ArcGIS Pro SDK support linear referencing?  Specifically, some of the functionality exposed by the ArcObjects IMSegmentation interface.
Methods such as:
  • GetSubcurveBetweenMs (gets the geometry defined on a route between measure m1 and m2)
  • GetPointsAtMs (gets the points from a route where a specific measure occurs)
  • SetMsAsDistance (sets the measures on a route based on distances)
So far, the closest I've found has been the CIMMarkerPlacementAtMeasuredUnits, which "Represents marker placement at geometry M values."
Is there other support in the SDK , and I'm just looking in the wrong place?
If that's the case - where should I look?
Thank you - Dale
daleward
Thank you Annette. I was just about to post a follow-up question regarding what to do if the measures on the route don't match the distance, so your reply is most timely
There may be a couple of other functions from IMSegmentation that we need as well - I'll post here as I come cross them.
