ArcGIS Pro (Core) Process Automatically Logs out of Portal Every 2 Weeks
767
04-21-2021 07:23 AM
MikeBHamsa
New Contributor II
Hello,
We've got a ArcGIS Pro command line process (using Core) that runs a batch operation on a scheduled process. The batch operation updates data published to a Esri Feature service and as such requires that ArcGIS Pro be logged into the Esri ArcGIS Portal. What were finding is that ArcGIS Pro is automatically logging out of the portal (around) every 2 weeks and it breaks the scheduled batch operations that is running on that machine.
How do we prevent ArcGIS Pro from logging out of the Portal every 2 weeks?
Mike...
CharlesMacleod
this is a default portal admin setting. it can only be decreased. 2 weeks is the max.
https://enterprise.arcgis.com/en/portal/latest/administer/windows/specify-the-default-token-expirati...
