Add Features to FC without it being a Feature Layer in the Map
2961
08-21-2015 04:56 AM
AdamDavis
I want to be able to add features to a Feature Class but not have to add that Feature Class to the map. Currently the snippets I see require that.
Any advice on how to do it?
Adam
ThomasEmge
Adam,
here is the code to do it. The caveat here is that this approach is not recommended for versioned data.
QueuedTask.Run(() =>
        string gdbPath = CoreModule.CurrentProject.DefaultGeodatabasePath;
        Geodatabase gdb = new Geodatabase(gdbPath);
        var featureClass = gdb.OpenDataset<FeatureClass>("Sample");
        var featureBuffer = featureClass.CreateRowBuffer();
        var newFeature = featureClass.CreateRow(featureBuffer) as Feature;
        newFeature.SetShape(pointGeometry);
        newFeature.Store();
AdamDavis
Hi Thomas,
Thanks for that. We did try something like that but we got some Not on this thread errors.
That's probably us as we added it to an existing synchronous codebase. What we'll do in future is have a test project that does simple things in the async world. Once that is working so we know what we are doing is Ok; we can then try and get it to run synched.
Thanks
Adam
SreevatsaSreeraman
New Contributor II
Hi Adam,
We do have snippets for creating a feature from given an sde file path. You can find it here https://github.com/ArcGIS/arcgis-pro-sdk/wiki/ProSnippets-Geodatabase#creating-a-feature.
It is recommended that edits have to be performed within the EditOperation. This allows for editing versioned/non-versioned data with undo/redo/discard/abort capabilities wherever required. Please see https://github.com/ArcGIS/arcgis-pro-sdk/wiki/ProConcepts-Editing#performing-edits  for more details.
Sree
AdamDavis
Hi Sree,
Thanks. Your links did not work but they did give me the clue to find them myself.
It would be nice if the snippets were more prominent on the web site.
https://github.com/Esri/arcgis-pro-sdk/wiki/ProSnippets-Geodatabase
Thanks
Adam
