Zoom in on ArcGIS map layout to show clusters of sites?
1550
04-13-2024 03:56 AM
EllaWes13
Hi!
So the subject may be a bit confusing but that's because I don't know what it's called, the thing I'm asking for.
Basically, I have a map of a country with several testing sites marked out all over the country, but in some parts of the country there are multiple sites quite close to eachother, so you can't really pick them out so clearly, it just looks like a big cluster. I'd like to show that in these clustered areas there are multiple sites, to make it clear for the reader.
Is there a feature in ArcGISPro map layout that lets you sort of add a tiny "window" next to the map that shows the clustered area zoomed in, so that it becomes clear that there are multiple sites in that area? Sort of like how you can have an tiny overview map of an entire country in a corner of a map that is a zoomed in part of the country?
I hope this question is clear, if not let me know! And thanks for any and all help!
Tags (1)
DanPatterson
MVP Esteemed Contributor
inset and overview map frames
see
Extent indicators—ArcGIS Pro | Documentation
... sort of retired...
JonathanMcD
EllaWes13
Hi! Thank you for your reply, but this is unfortunately not what I was after.
DanPatterson
see
EllaWes13
Thank you for this, this was what I was looking for!
