Feature To 3D by Attribute was used to create a new line feature class using upstream and downstream elevation attribute values. If viewed in ArcMap, new 3D z values match with attribute values as they should. In ArcGIS Pro, all the values in the vertices are showing as 1.1m higher than attribute values. What would be the cause of this difference?
same horizontal and vertical coordinate systems in the map/data frame?
