XY Table to Point not working - it only works without ''Date'' column
4423
9
03-21-2024 10:02 AM
GabrielBordonal
Hello!
I am having an annoying issue with arcgis Pro 3.2 . Since i ve updated to the 3.2 version, XY table to point simply doesnt work. When i remove the date column, it works fine. But i need this column to be used as a filter.
Any help on what may be happening?
I've already tryed to change date formats in the csv file ;
imported as a event (it goes well) but when i try to export to a shapefile it simply doesnt work as well.
I am very grateful to anyone who can help me.
Robert_LeClair
Esri Esteemed Contributor
The DateOnly field is a new field type introduced in ArcGIS Pro version 3.2. In previous releases, the field is read as a Date date field type. For more information, refer to https://pro.arcgis.com/en/pro-app/3.2/get-started/whats-new-in-arcgis-pro.htm.
DateOnly fields cannot be created in the shapefile format; thus, tools that export the table to that format raise an error. This error message is to be made more consistent in time, indicating that the reason the output table cannot be created is due to the unsupported field type for the output format.  The workaround is save the output as a file geodatabase feature class instead of a shapefile.
Eugene_Adkins
I'm using 3.1.1 for multiple reasons so I can't replicate your workflow, but maybe a workaround would be to create two versions of your table - one version with the date and the version other without the date.
In each of these tables create a matching/identical column with unique populated information that could be used for a join after you create your points from the non-dated table. Once the points are created, you can join the points to the table with the dates and then field calculate the dates into the newly created points layer. Not ideal for sure, but it may help you move forward with your work in the meantime.
GabrielBordonal
Thank you for your help.
It worked, but unfortunately the data can't be filtered (don't know why). Apparently theres a issue with the SQL (?).
Anyways, i'll save it as a geodatabase. Thanks.
DanPatterson
MVP Esteemed Contributor
There have been soe changes
BUG-000163458 for ArcGIS Pro (esri.com)
... sort of retired...
GabrielBordonal
Thank you. Seems i'll need to work with geodatabase now.
Robert_LeClair
RichardDaniels
Honored Contributor
How about the ESRI dev team add three lines of code to NOT export a DateOnly field if the export type is a  Shapefile? Updating a tool intentionally to break existing functionality is considered Bad and should be avoided. Hopefully, ESRI is addressing this since shapefiles are still supported by ESRI and are used by many open data solutions..
Robert_LeClair
@RichardDaniels - as I work in Esri Training Services and not the ArcGIS Pro Development Team, I don't have an answer for you unfortunately.  I did a quick search on the ArcGIS Pro Ideas page and did not see an idea listed on this topic.  One thing I can recommend is to add this as a new idea so it gets visibility with the Dev Team.  I know Esri staff on the ArcGIS Pro team do read these ideas and try to incorporate new/modified workflows with each release.
GabrielBordonal
Thanks for your help.
Robert_LeClair
Certainly!  If you feel mine or another's response provided a solution to your question, please click the "Accept as Solution" button for that answer to close out this thread.  Have a great day!
