X and Y Coordinate Selection Not Giving An Option of All The Headings From my Excel Spreadsheet
1115
01-08-2024 11:40 AM
LaurenWilliams23
Hello,
I am having issues trying to input my excel table into x an y coordinates. I have attached an image to show the headings that I have been using.
Once the table is selected there is only an option of latitude for both x and y coordinates. I have tried changing the titles and moving to a new spreadsheet but nothing is working
I have inputted the exact same layout of data for different locations already and it’s been fine.
DanPatterson
MVP Esteemed Contributor
Did you try Excel To Table (Conversion)—ArcGIS Pro | Documentation
to get the excel file into a geodatabase table first. From there you can use
XY Table To Point (Data Management)—ArcGIS Pro | Documentation
to create a point featureclass
... sort of retired...
MarcelSt-Germain
I had some trouble to.  What I find is the type of data for my field was the source of the problem.  When inserting X and Y coordinates, Pro check for numeric field.  If not find, it doesn't show.
For me, since I use imported coordinate in text, I close the problem by making a calculate of that field in a numeric one and it's finely show in the parameters.
