Why would ArcPro create longer Text Field lengths than ArcMap?
2995
8
04-03-2019 05:03 AM
CharlieKaufman
New Contributor III
I recently brought in an excel table of schools in ArcPro, and loaded the x/y coordinates to export out a layer to a geodatabase.   When I looked at the layer properties of the new data I just created I was shocked to see that ArcPro was creating "monster" text fields of 2,147,483,647 in length.   When I exported the exact same excel file in ArcMap the text fields were the generic 225 in length.
This is going to cause some serious issues when I try to start merging older and newer files together.  Not to mention space savings in the long run.
Is there a setting I am missing in Pro, or is this another case of it not liking excel?
Trying to reason (and map) with hurricane season.
Scott_Harris
Hi Charlie,
In Esri Technical Support, we have the following defect report logged:
[BUG-000097684 XLS and XLSX files opened in ArcGIS Pro have extremely large text field lengths.]
The status of the defect is "In Product Plan", meaning the developers intend to fix this issue in a future release of ArcGIS Pro.
If you want to track (or have a case attached) to this defect, please contact Esri Technical Support - https://support.esri.com/en/contact-tech-support
-Scott
curtvprice
MVP Esteemed Contributor
I don't know the whole story here (it isn't mentioned in the docs) but I do know that (unlike shapefile/.dbf) the file geodatabase isn't actually allocating 2GB of spaces for each record, that field width is a maximum size of the string, not what is stored. If you convert this dataset to shapefile/.dbf, this could be an issue because those formats actually DO write spaces to fill out string fields.
If you load data into the database with the Table to Table or Feature Class To Feature Class tool, you can modify the field map to specify any text field maximum length you want, as long as the data you have fits.  If it doesn't fit, you can even truncate it with the field map start and end columns.  The field map also gives you full control over field names and numeric data types. For example, you can specify float, Short, or Long, when the default is to bring all  Excel numeric data in as Double.
DanPatterson_Retired
Try using
Excel To Table—Conversion toolbox | ArcGIS Desktop
It wasn't clear whether you just loaded the excel file or used the above tool to attempt a conversion to a geodatabase table.
curtvprice
I've been meaning to do this exercise in Pro 2.3 to see how this is different from ArcMap so I did a little test.
Here's my excel table and .csv version:
excel table
FIELD1,FIELD2,FIELD3
aaaaaa,01,1
aaaaaa,02,2
aaaaaa,03,3
See the screenshots below. The top table view is what I see when I view .xlsx and .xls format in Pro, the middle is what happens when I view the .csv, the bottom is a table when I read in the .xls using the Excel to Table tool (reading the .xlsx version of the file). As you can see these three imports use different tools to read the data so we get three different interpretations of the same Excel data file.
Note my text codes ('01, '02, '03) get numerified in the CSV import but are still text in the excel imports. Not a trivial deal when trying to load in county FIPS codes or USGS site IDs that can have meaningful leading zeros!  This is an improvement over ArcMap, even if the field widths are silly.
Excel is not a database.
excel file import
hmmmm maybe the Canadian versions of excel and Pro work differently
If I have to work with excel, I always explictly format the columns though
curtvprice
Dan, your results for the excel to table tool are exactly the same as mine (Pro 2.3b2 was the exact version). The difference in the screen shots is that yours are from table views opened from a map's TOC, my screenshots are tables opened directly from the catalog.
I agree formatting the excel sheet can help. But you gotta check! Trust, but verify.
even more interesting, is that NumPyArrayToTable handles the conversions even better maintaining the data's field width for string/text data
/blogs/dan_patterson/2018/12/13/excel-arrays-tables-in-arcgis-pro
arr = excel_np("c:/temp/x.xlsx")
arr
array([('aaa', '01', 1), ('bbb', '02', 2)],
      dtype=[('field1', '<U4'), ('field2', '<U4'), ('field3', '<i4')])
import arcpy
arcpy.da.NumPyArrayToTable(arr, r"C:\...space_less_path\a.gdb\x_arr")
Scott_Harris
Hi Charlie,
-Scott
CharlieKaufman
New Contributor III
Thanks Scott.   I will go about seeing if I can add my case to this defect.
-Charlie
