Why was Legend not able to give you the options when you highlight columns when you manually the columns ?
758
11-27-2023 10:41 AM
DEAF_PROBERT_68
Honored Contributor
I am working on legend for my map and it really change a lot but the only question is  :
1) When you are in the Layout and made a selection or highlight Legend. It give you the options in the Element.
2) When you decided to work on your Legend Arrangement Options and I set to Manual Columns in the Fitting Strategy with 4 Columns.
3) Now when you have these set it up .  On the Drawing Order, I have  Column 1, Column 2,  and so on...  So why was there no option when you make the selection/highlight to give you the options...
See this screenshot :
This gives me nothing to give options for each column 1, column 2, and so on ??
The reason I am asking is because we need these options to open so we can manually fix the legend ?  This is a  very limit and hard to work with just one legend only ?
Should I add these to the ArcGIS Ideas or will it be working on the next new versions ?
