Hi everyone, I'm creating a model tool in ModelBuilder on ArcGIS Pro. So far, the geoprocessing finished with no issues, but the results isn't what I expected. It's over the boundary I selected. I ran a few times back and forth, unfortunately same result. Can someone help please ?
Hi @JessicaJiang , probably you could add a "calculate value" in "Export Features (2)". Maybe is better to add in the "Expression Area" one value for only for the area and the right , column from the attribute table.
You could also check these two links https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/select-layer-by-attribute.ht...
Best Regards
Nektarios
