Why have my Merged and Composite Band raster layers suddenly have broken data sources?
570
03-01-2025 11:41 AM
Labels (3)
ScarletMaguire
I have several single band raster layers in my ArcGIS Pro project which cover a large area; these are 1-band Red, Green and Blue reflectance layers; and I have 10 layers for each colour (30 layers in total). These layers when put together cover a continuous geographical area. I first used the Merge Rasters (Data Management tool) to merge them; this created 3 layers covering my area. Second, I used the Composite Bands (Data Management) tool to use these 3 layers to create a single RGB layer. This worked well and the result was great. However, when I re-opened the project later the merged layers and composite band layers are no longer on the map: they are in the contents pane but they have a missing data source. However, the original single-band rasters are still in the map without a broken data source.
My question is, how do I merge layers, and create composite band layers, and actually keep them in the project for the long term without them getting a missing data source?
Thank you in advance for any help.
DavidPike
MVP Notable Contributor
Where are you saving them to initially and what location is the broken source referencing?
DanPatterson
MVP Esteemed Contributor
Composite Bands (Data Management)—ArcGIS Pro | Documentation
try saving as a *.tif in a folder.
... sort of retired...
