Why don't photo attachments show up in reports created in ArcGIS Pro?
1906
23
02-25-2020 01:40 PM
JamesDaniels
I'm trying to generate a report in Arc GIS Pro 2.5 that include the photo attachments. I insert a box for the attachment using the attachment button in the data section of the insert tab, but when I run the pdf maker under the share tab place for the attachment is blank.
EricPeña
I have the same issue trying to migrate reports from ArcMap over to ArcGIS Pro.  Photo attachments are a requirement and I was hoping that the new Attachment Report Elements feature would work but I can't get attached images to show either.
AzinSharaf
Could you fix this issue? I have same issue with attachments.
ChrisGaylor
Same issue here. Did you ever find a solution?
IsaacSorensen
I found a solution to this problem. If you are running pro in windows 10 go into your registry editor on your machine. Find the JPEG extension. Change the extension from .jfif to .jpeg.
JamesDaniels
Once I updated to the latest version of Pro, the problem resolved itself. The photos now show up.
ChrisGaylor
Thanks for the suggestions. Checked my registry settings and .jpeg was already the extension there. Also, I'm running ArcGIS Pro 2.5.2 and it's still not working. In my case, I have an inspections table with attachments enabled. I'm trying to get a report of Site Name, Inspection Date, and the attachments in a grid. Everything exports except the photos. May have to open a support ticket on this one.
MeredithDutlinger1
Hi there.  Did you ever open a ticket for this and figure out any magic you can share?  I am also having this problem!  Thanks so much for any info ....
ChrisGaylor
I never got around to opening a ticket on it, however, when I upgraded to ArcGIS Pro 2.6 the problem went away! I re-created my reports and the attachments are working great now! The 2.6 version seems to have made several changes with reports because the entire process seems to work better now.
MeredithDutlinger1
I know, I was so excited for 2.6 and all it’s new functionality, but my attachments still aren’t showing up. If I open a ticket which is looking likely, I’ll be sure to share what I found out. Thanks for your response Chris!
