Why does metadata not populate in Item Details when sharing as a Map image layer?
413
07-02-2019 09:43 AM
by Anonymous User
Not applicable
When I publish a raster as a map image or a tile layer the metadata that is attached to to the layer is automatically populated in the item details of the sharing pane. However, if I share as a map image layer the metadata does not populate and I have to manually enter in this information. Is this a bug or is there a reason? Thank you!
curtvprice
I am wondering if full item/description metadata is supported, as the Pro help says that only the summary and tags are prompted for when you share these items. So I don't know, I maybe a call to tech support is warranted as no one else has chimed in. If you find out, please update this thread.
