What versions of Pro are compatible with 10.7.1 EGDBs?
666
03-25-2022 01:03 AM
Bud
Notable Contributor
I'm hoping to update my version of ArcGIS Pro (2.5.0) to the latest version of Pro that will support our current 10.7.1 EGDB (Oracle 18c).
I've heard a rumor that modern versions of Pro aren't compatible with older EGDBs -- although I don't have specific details.
Is there a way to determine what versions of Pro work with 10.7.1 EGDBs?
Thanks.
JayantaPoddar
George_Thompson
Esri Frequent Contributor
Newer versions of Pro can connect and use "older" versions of the Enterprise Geodatabase. The limitation might be related to supported RDBMS / functionality available.
--- George T.
Bud
Notable Contributor
Thanks.
It turns out, the compatibility issue is with license manager. I can upgrade Pro to version 2.6.8, but anything beyond that would be incompatible with our version of license manager.
George_Thompson
Could you upgrade to the latest version of License Manager?
It would be backwards compatible to previous versions.
--- George T.
