I'm hoping to update my version of ArcGIS Pro (2.5.0) to the latest version of Pro that will support our current 10.7.1 EGDB (Oracle 18c).
I've heard a rumor that modern versions of Pro aren't compatible with older EGDBs -- although I don't have specific details.
Is there a way to determine what versions of Pro work with 10.7.1 EGDBs?
Thanks.
Newer versions of Pro can connect and use "older" versions of the Enterprise Geodatabase. The limitation might be related to supported RDBMS / functionality available.
Thanks.
It turns out, the compatibility issue is with license manager. I can upgrade Pro to version 2.6.8, but anything beyond that would be incompatible with our version of license manager.
Could you upgrade to the latest version of License Manager?
It would be backwards compatible to previous versions.
