I'm trying to understand .lyrx files and I don't find much info about the .xml files referenced in them. For example, I exported the symbology for a layer called "hydroWaterBodies" (first part below), but don't find this map/hydrowaterbodies.xml anywhere on my computer. I understood it's for the layer metadata? Where is this file located? Any clarification on this?
"type" : "CIMLayerDocument",
"version" : "2.7.0",
"build" : 26828,
"layers" : [
"CIMPATH=map/hydrowaterbodies.xml"
"layerDefinitions" : [
"type" : "CIMFeatureLayer",
"name" : "Water body",
"uRI" : "CIMPATH=map/hydrowaterbodies.xml",
"sourceModifiedTime" : {
"type" : "TimeInstant"
"build" : 26398,
"layers" : [
"CIMPATH=npgeom_tests/x2.xml"
In the above example The CIMPATH refers to the map (npgeom_tests) that the input layer resides.
The actual location of the geodatabase that file that it references is given later.
"workspaceConnectionString" : "DATABASE=..\\tests.gdb",
The lyrx references what was use to produce the file and the properties of the symbology. If you are looking to see a nice little package describing the symbology, you will have to scroll through lyrx and its multitudinous list of nested curly brackets 😁. The above simple lyrx file that I extracted the examples from was only 1433 lines long. But it is best not to mess with the file
Thanks, it's clearer now.
No problem. You may want to close the thread if your question was answered
