What is the future of ArcCatalog in future Pro versions?
30164
81
02-10-2015 11:59 AM
RenatoSalvaleon
Unless I missed it, there's several Administration features in current ArcCatalog that are not available in Pro, specially the ones for geodatabases, e.g., Manage and Administer which is slightly different for each type of data objects.
MichaelVolz
Esteemed Contributor
George:
Thanks for the response.  I am curious to see if you are using Attribute Assistant (AA) to update SDE feature classes in ArcMap.  If so, do you see this being a problem for your migration to ArcPro as there is important functionality still not available in Attribute Rules (Pro's equivalent tool to ArcMap's AA)?
GeorgeBrown1
Michael,
We are not using AA.
Blessings,
George A. Brown II, GISP
GIS Manager
Jacksonville Sheriff's Office
17RMP3734154988 USNG
904.630.2932 P
904.239.1395 C
904.630.4709 F
Hours: M-F 0600-1430 EST
George.Brown@jaxsheriff.org<mailto:George.Brown@jaxsheriff.org>
**IMPORTANT MESSAGE / CONFIDENTIAL NOTICE / FOR OFFICIAL USE ONLY**
This message, including any attachments, is intended for the use of the person or entity to which it is addressed and may contain confidential information and/or otherwise privileged or restricted material. Any dissemination, distribution or copying of this information is STRICTLY PROHIBITED. If you received this communication in error, please alert the sender and delete the information.
Unless otherwise noted, the material contained in this document is considered active criminal intelligence and as such, is exempt from disclosure via the Florida Public Records Law (F.S.S. 119.07)
MichaelVolz
The limitations of AR compared to AA is definitely a big issue at my org as that is part of our planned architecture moving forward to update very important enterprise SDE feature classes.
Since this is not an issue at all for your org, what would you say are the biggest issues to moving to Pro?
Would you consider the performance issue of SQL Server SDE in Pro a showstopper at this time?
GeorgeBrown1
Right now our biggest issue the learning curve of “where is everything” from our users. They will try it, not like it, and not use it. Icon styles were an issues so we downloaded some new styles from ESRI and that helped. A/C not being there is one of my two biggest complaints. The other is in using the Find tool in AM had a great work flow I used all day, every day after finding the address and then the right click option to add a point and then add a text box to that location. Not an option in AGP from what we are being told (see below from ESRI UC AGP Team this week). Right now, and we are just starting to work with importing our large MXD files into a new blank AGP Project, we are finding this extremely time consuming on the import and the projects are VERY slow to open if they have SDE connections.
Here is the work flow for example in AM:
Right click to add a call out text box, for example. Here are the steps in AM also and snap of what we are looking for in AGP:
  • Take any AM .mxd
  • Use the Find Tool to search an address using our own Address Locator, for example our ROADS locator
  • From Find Window, select the Locations Tab, choose our ROADS locator, plug in the address in the Full Address line, hit Find. Our address appears
  • From there you right click on the address in the Match_Addr and you have all the options on what to do. Where are these option in AGP??
From ESRI UC Pro Team in response to the above:
“it’s not there. The reason is that the end result is graphic text (mostly) and graphics are not supported in Map Views in AGP. They’ve heard from many customers that they want graphics support so they are strongly leaning in that direction to implement – perhaps 2.3 (scheduled for end of the year)”
Blessings,
GIS Manager
904.630.2932 P
904.239.1395 C
904.630.4709 F
MichaelVolz
For your big issue with Pro not supporting graphics in the mapview have you voted up the following idea:
https://community.esri.com/ideas/10410
Voting is how Thomas Colson was able to get ESRI to say you will never be able to publish services directly to ArcGIS Server from Pro to now it being implemented in Pro by mid-2019.  Voting on ideas is power.  This idea is up to a score of 1480 on 7/12/2018, but it needs to go much higher than that for ESRI to move the idea from Under Consideration to In Product Plan.
GeorgeBrown1
Thanks for the vote link. Guess I missed that one. Voted up now and as several mentioned, Map Notes is not the answer.
Blessings,
GIS Manager
904.630.2932 P
904.239.1395 C
904.630.4709 F
curtvprice
There are resources on the Esri Academy (formerly "training" formerly "online campus"):
https://www.esri.com/training/catalog/5b296eb4e620ca23e65420dc/migrate-to-arcgis-pro/
and, a useful book was recently released: Switching to ArcGIS Pro
KoryKramer
Esri Community Moderator
Thanks for sharing those resources, Curtis.  As ArcGIS Pro is a new piece of software, there is a learning curve.  In addition to what you've shared, here is a list of resources that I've compiled (I've shared this before in various places around GeoNet.  Hope this is helpful to those interested in ArcGIS Pro.
Overview of ArcGIS Pro Licensing
ArcGIS Desktop licensing
Named User licensing in ArcGIS Online
ArcGIS Pro Named User licensing
Terminology Guide
http://www.esri.com/library/brochures/pdfs/arcgis-pro-terminology-guide.pdf
Training: Tutorials and Exercises
Quick Start tutorials
Learn.arcgis.com Lesson Gallery (filter by Product = ArcGIS Pro)
Migrating from ArcMap to ArcGIS Pro
ArcGIS Pro: Essential Workflows
Going Pro: ArcGIS Pro Essentials for ArcMap Users
ArcGIS Pro: Editing Essentials
ArcGIS Pro: Analysis and Geoprocessing Essentials
Beyond the Quick Start Tutorials:
Authoring and sharing maps: Author and share a mapAuthor and share a local scene
Map layouts: Work with a table frameWork with a grid
Python: Create a map book with Python
Geocoding series beginning with: Find addresses
Network Analyst series beginning with: Create routes
Data Reviewer series beginning with: Store validation results in your project
 Help
For ArcMap users
Import a style into the project
Python in ArcGIS Pro
Analyze Tools For Pro
Analyze custom geoprocessing tools for ArcGIS Pro
Python migration from 10.x to ArcGIS Pro
Migrating from arcpy.mapping to ArcGIS Pro
Migrating arcpy.na to ArcGIS Pro
ModelBuilder: migration to ArcGIS Pro
Migrate locators to ArcGIS Pro
Migrate raster catalogs to geodatabase mosaic datasets
Upgrade Dataset
Migration from ArcMap to ArcGIS Pro for data validation
Tools that are not available in ArcGIS Pro
Videos
ArcGIS Pro Editing Essentials
ArcGIS Pro: Tips and Tricks
ArcGIS Pro YouTube Playlist
Blogs
Dude, where's my Catalog?
ArcGIS Pro Tips: Why Undo is Underrated
ArcGIS Pro Tips: Get Your Maps in Sync
ArcGIS Pro Tips: Scroll Around The World
ArcGIS Pro Tips: Shortcut Savvy Navigation
ArcGIS Pro Tips: Scale-Based Symbol Sizing
ArcGIS Pro Tips: Thinking About Linking – 2D and 3D Views
ArcGIS Pro Tips: 5 Tips For Fixing Broken Data Links
ArcGIS Pro Tips: Save Time With Bookmarks
ArcGIS Pro Tips: Group Templates, Galleries, & Grids Make Editing a Snap
ArcGIS Pro Tips: This Might Just Be Your Favorite Tip Ever
ArcGIS Pro Tips: Customize Without a Line of Code
ArcGIS Pro SDK Development Series, Part 1:  Getting Started
ArcGIS Pro SDK Development Series, Part 2:  Learning the Pro SDK
BOOKS
Getting to Know ArcGIS Pro
GIS Tutorial 1 for ArcGIS Pro: A Platform Workbook
Understanding GIS: An ArcGIS Pro Project Workbook
Making Spatial Decisions Using ArcGIS Pro: A Workbook
curtvprice
Hey Kory, nice meeting you at the UC! Is this posted as a doc somewhere? I'm having trouble finding it so I can refer to it later. The training folks have posted a few similar docs too. There sure is a lot of stuff out there, which is good!
https://community.esri.com/community/education/blog/2018/05/24/arcgis-pro-training-guide-may-2018
curtis and kory uc 2018
KoryKramer
I just posted it as a document https://community.esri.com/docs/DOC-12082-arcgis-pro-learning-resources
Thanks for sharing that training guide - I didn't know about that!
