What are the columns in cross validation results for interpolation?
559
04-19-2023 01:47 AM
Labels (2)
JiefengKang
Hi, I used ArcGIS 10.x (I know, it is quite old - I use that for some reason ...) and get a cross-validation result before applying the interpolation. The analysis process of ArcGIS 10.x is similar to that of ArcGIS pro, and I read that the results are also similar. The cross-validation result is a point shapefile, the attribute table of which looks like this:
I know some of the columns:
FID - The id of the features of this generated point shape file.
Shape - Type of the features.
Measured - Actual value of the point.
Predicted - Predicted value of the interpolation method using the leave-one-out method.
Error - The difference between the predicted value and the measured value.
But for the others, I am not sure what they are:
StdError - Standard error? How do we calculate it?
Stdd_Error - ?
NormValue - ?
Source_ID - The id of the original features/points?
Included - It says "yes" or "no". Does that column indicate whether the point is left for the final interpolation after the cross-validation?
Thanks for your time.
