Voxel Isosurface to Raster? Or Displaying Depth Contours on the Isosurface?
81
2 weeks ago
geolane93_KU
Hi there,
I'm trying to figure out how to best represent an isosurface for a publication. The isosurface is from a voxel volume of subsurface temperature. I think it would be best if I could export the isosurface to a raster which I could then generate contours showing depth to the particular temperature. However, I can't seem to find any way to do this. Another option would be to show depth to the isosurface contours in 3D and then make the figure. However, I again can't seem to find any way to generate contours of the depth values for the voxels. The figure will be pretty useless without some sort of way to show the depth to the isosurface.
The voxel volume was created using the GA Layer 3D to Net CDF tool.
Thank you for any help.
geolane93_KU
No comments? Is there no way to stretch the color bar over depth rather than predicted value?
