I have a valid version 1.0 3D Tiles service that is not loading in ArcGIS Pro 3.2.1
Here is the service endpoint:
https://vic.digitaltwin.terria.io/api/v0/data/038d699f-9167-4dbc-9920-cb9b2c24786c/v2/tileset.json
It is a valid 1.0 version 3D Tile service. According to Esri's public release on the topic,
"With the latest update in ArcGIS Pro 3.2, you can incorporate 3D tiles layers from 3D tiles datasets version 1.x. Your data can be both local sources and public web services." (Emphasis mine)
Verification of functionality (QGIS add scene connection):
Result in ArcGIS Pro 3.2.1:
What I've tried:
Adding as global scene
Adding as local scene
In local scene, forcing projection by setting both horizontal/vertical scene projections to the layer itself
No errors are offered; however, the service does not render. Ideally the service should render, or throw an error if it cannot render properly. Ideas?
