Using edit to connect two disjointed pieces of the same polygon
1013
10-26-2022 10:33 AM
LucasBeck
Hi Everyone,
I have a file geodatabase feature class, that contains a single object that is a polygon. However, the polygon is not continuous. There is one island that I would like to connect to the larger main portion of the polygon. I tried to use the edit vertices tool, to connect the small part of the polygon to the larger, but I could not find a way to delete the internal divisions between the former island and the main polygon. In other word I could edit the vertices to get the two pieces to overlap, but not to merge into a single object without internal divisions. I tried using the merge tool, the dissolve boundaries tool and the dissolve tool, but I think these failed because the pieces are both part of the same polygon contained within a single layer. Does anyone know a way that I can edit the pieces of these polygons to merge them together without any internal divisions? Thanks so much for any advice.
Best regards,
Lucas
RhettZufelt
MVP Notable Contributor
Hard to visualize without a snapshot, but if you are trying to get rid of internal veticies like below, you can go to edit verticies:
Then, while holding down the "D" key, drag a selection around the internal vertecies to delete them:
R_
RhettZufelt
R_
LucasBeck
Worked great! Thank you!
