Updating a related table field with information from feature layer field
536
11-23-2021 04:03 PM
by Anonymous User
Not applicable
I am using ArcPRO to create a feature layer and related tables.  This will eventually be a field map/collector app.
One of the fields in the feature layer is address.  If I wanted that address field to populate a field in a related table, can that be accomplished?  I believe I heard ESRIs Eric Wagner @EricW mention this could be accomplished in a video, but didn't mention how as this video wasn't specific to that topic.
Thank you!
Tony_DLR22
Greetings!
Where will the data be published to? ArcGIS Online? ArcGIS Enterprise/Portal? If so , what version?
by Anonymous User
Not applicable
Data will be published to ArcGIS Enteprise/Portal.  Today we are updating to 10.9.1.
Thank you,
Annette
Tony_DLR22
Hi Annette,
A calculation Attribute Rules may work for this. Try seeing what MikeMillerGIS has on Github.
Not sure if you're familiar with Arcade expressions and Attribute rules but may be worth a try. Maybe some variation of the one below?
https://github.com/MikeMillerGIS/arcade-expressions/blob/master/attribute_rule_calculation/MoveField...
