Update Table Row Error
1063
04-05-2019 04:51 AM
ThomasJordan
I am trying to edit an attribute value in a hosted feature layer.
When I edit the value in ArcGIS Pro I get an error message stating:
Update table row failed
General function failure [invalid column name
'AUTHORIZED'.]
Error Message in ArcGIS Pro
When I attempt to make the edit using Map Viewer in ArcGIS Online, I get an error message stating:
Accessing data failed
Error Message in ArcGIS Online
One further note. I had a field named 'AUTHORIZED' but I deleted that field yesterday, before this problem arose.
VictoriaAnderson
Hi Thomas,
Can you try downloading the hosted feature layer as a file geodatabase and republishing it? Does the same issue occur with the new layer?
ElizabethNaro
I have this same issue and tried downloading and republishing with no success. The error message is slightly different now as shown below. Any other suggestions?
