Undo a field calculation in ArcPro
5137
12
10-27-2016 06:59 AM
RichardHughes2
How is it possible to undo a field calculation in ArcGIS Pro?  In ArcMap the edit session allow for undo, in ArcPro what is the solution?  There is a solution for this right?  Otherwise field calculations are not safe.
KoryKramer
Community Moderator
At ArcGIS Pro 2.7 an option was added to have Enable Undo toggled on by default: Geoprocessing options—ArcGIS Pro | Documentation
SarahEFox
How do you keep this toggle on?  I'm having to click it on each time - and I would rather just have it on permanently.
Signature for a badge - a fair trade.
KoryKramer
Community Moderator
Go to Geoprocessing Options:
Read more about that setting and considerations to keep in mind here: https://pro.arcgis.com/en/pro-app/latest/help/analysis/geoprocessing/basics/geoprocessing-in-an-edit...
