Unable to Upgrade Pro 2.3.3 from 2.3.2
4184
06-10-2019 08:12 AM
ShawnRoberts1
Hi all, I'm attempting to upgrade to Pro 2.3.3 but every time I do I get a "Microsoft Installer failed to Run. Fatal Error during Installation". The logs show a "ERROR MSIInstallProduct failed: error code = 1603". I've never had any issue installing before.
I've went through some steps trying to clear this error
   -  Followed this guide
   - cleared temp files there is now nothing in it
   - ensured no locks existed (did a reboot then tried an install)
   - it's not permissions as I'm running as admin
Before I completely uninstall 2.3.2, I just wanted to see if any one has experienced this and how they went about solving it.
ShawnRoberts1
Just as a follow up. I ended up taking copies of all my projects, symbols ect, uninstalled pro (I didn't bother deleting registry keys or anything fun like that), reinstalled the same version 2.2.3 then updated and it worked perfectly. Not sure of the why but it worked.
RobertBorchert
Honored Contributor
Are you operating as an unrestricted administrator.
ShawnRoberts1
Hi Robert, thanks for the advice!  I'm updating as a Local PC admin, with full control over the computer I'm attempting to update. I have updated this particular PC many times in the past with no issues.
RobertBorchert
Honored Contributor
I recently updated also with no issues.
When trying the update while in Pro do you have any active portals.  I don' think it should make a difference but may only be logged into where you licensing is located.
ShawnRoberts1
Unfortunately only one active portal and that's ArcGIS Online. Kind of a mystery at this point. I feel like just taking all the files i need from 2.3.2 uninstalling, reinstalling, and then dumping the files back may be the easiest solution.
ShawnRoberts1
