Unable to update to ArcGIS 3.3
5157
13
05-13-2024 01:20 PM
FlightDeck
Hey all,
I am trying to update to ArcGIS 3.3 but keep running into an issue with Microsoft edge WebView 2 Runtime. Although it is installed and up to date I am unable to get past this error (image Attached). Has anyone else encountered this? How did you get past it? I am unable to uninstall it, but I can and did run a repair to no avail.
DanPatterson
MVP Esteemed Contributor
Tech Support
They may have case specific suggestions that aren't on the public facing support site.
... sort of retired...
HeatherRoy
I'm having the same issue. Both are installed, Pro still wont update.
MattWilkie3
Same issue here. It first surfaced with a Dell Precision 3360. A laptop imaged same day from same image has no problems. Here's a reddit thread with a detailed breakdown of their deployment means, with same problem. We use a very similar method.
https://www.reddit.com/r/Intune/comments/1gz6b62/install_arcgis_pro_33_intunesccm_webview2_runtime/
I'll open a support issue and report back
MattWilkie3
Tech support says we're on our own. Unattended installs are not supported. The Reddit thread continues see traffic and might someday reveal something useful. We hope anyway.
Hello Matt,
Thank you for your patience.
 I've had the chance to review the scope of the installation internally, but unfortunately SCCM deployments fall outside of the scope of ESRI technical support. I would recommend installing the application without SCCM on those machines that are experiencing unexpected behaviour, and if the issue still persists, we'd be happy to continue to troubleshoot as to why that might be.
Thank you for your understanding.
https://my.esri.com/#/support/cases/tech-cases?caseNumber=03784075
Esri Canada
