Unable to open Web map on ArcGis Pro
108
2 weeks ago
ZimasaGroom
New Contributor II
I am having issues with opening Web map on ArcGis Pro.
When I select the ArcGIS pro option, it automatically opens on ArcMap.
it is not downfolding   .pitemx I am running 2.7.3
Tags (3)
JayantaPoddar
MVP Honored Contributor
Could you confirm when you click "Open in ArcGIS Pro", item.pkinfo gets downloaded instead of item.pitemx?
Does it happen with all the webmaps or with one particular webmap? Are you working with ArcGIS Online or ArcGIS Portal?
ZimasaGroom
New Contributor II
Item .pkinfo gets downloaded when I click "Open in ArcGIS Pro"
it is happening with all webmaps.
