Unable to create Topology in dataset
1064
11-17-2022 03:23 AM
PaulDhandapani
I am unable to create a new Topology inside my dataset I've created recently.  It's always throwing error "ERROR_160621: Cannot add a class that is registered as versioned to a topology that is not registered as versioned."
Any ideas/thoughts welcome...
~Paul
DanPatterson
MVP Esteemed Contributor
160621: Cannot add a class that is registered as versioned to a topology that is not registered as v...
There is a solution there, but it involves contacting Tech Support with information since it is a rare occurence
... sort of retired...
Robert_LeClair
Esri Esteemed Contributor
Presuming that all feature classes in your feature dataset are registered as versioned before you create the GDB topology, then this error message "should" not appear.  BUT if all FC's are registered as versioned before creating the GDB topology, then this sounds like BUG-000134929 - ArcGIS Pro allows creating a topology on a versioned feature dataset after returning an error message.  It was discovered at 2.6.2 and is under review by the ArcGIS Pro Dev Team.
