Unable to Add Layer into a .prjx - mismatch of: # ofshapes and table records
57
yesterday
JRodriguez_CMAPGIS
Working in ArcGIS Pro 3.1.3, and attempted to bring a data layer (.shp) into a .prjx
However, I was undable to add the layer receiveing an error message stating:
FAILED TO ADD DATA __________.shp
NUMBER OF SHAPES DOES NOT MATCH NUMBER OF TABLE RECORDS
Is there a means of correcting either (+ or - number of shapes in the .shp or the number of records in .dbf/.txt) so that the layer is usable once again?
RhettZufelt
MVP Notable Contributor
Have you tried running the Repair Geometry GP tool on the shapefile?
R_
