Unable to add Branch Versioning to FeatureDataset
464
12-05-2018 04:08 AM
Hey Everyone,
I'am trying to register a feature dataset with branch versioning but I am constantly getting the error message
 ERROR 999999: Something unexpected caused the tool to fail. Please refer to the error help for potential solutions, or contact Esri Technical Support http://esriurl.com/support.
 Invalid Multibranch registration  [UTARC.StructureJunction_1]
 Failed to execute (RegisterAsVersioned).
When i delete the feature class StructureJunction_1 from the feature dataset, I get the same error message for another feature class. If I delete that also, I get the error message for the next feature class in the feature dataset and so on.
I am using ArcGIS Pro 2.2.4. The database is an oracle database and my SDE connection file is created with branch versioning enabled.
Can anybody give me a hint what I am doing wrong?
Reply
Esri Frequent Contributor
Have you followed the workflow for enabling branch versioning? Are there any errors during this process?
Register data as versioned—Geodatabases | ArcGIS Desktop
Geodatabase
--- George T.
Geodatabase
--- George T.
Thanks for your answer.
We are using Oracle Spatial and not ST_GEOMETRY. We willl change the geometry type of the database.
Is there any plan to support Oracle Spatial in the feature?
Am I correct that in postgres I could use both ST_GEOMETRY and the PostGIS geometry type?
Reply
I would say yes for Postgres, you can use either spatial type.
--- George T.
Reply
