Turn the Swipe off in ArcGIS Pro, when finished using
5575
03-22-2018 09:35 AM
ChadKopplin
I am unable to turn the swipe off in ArcGIS Pro, when I am finished using the tool.
JormaHuttunen1
I had a same problem but I was able to deactivate Swipe by navigating to Map tab, then click the Explore button.
Robert_LeClair
Esri Notable Contributor
To add to Jorma's reply, you could right click on the Explore tool and add it to the Quick Access toolbar top left of ArcGIS Pro.  By doing so, you don't have to click the Map tab to activate the Explore tool.
JormaHuttunen1
Thanks Robert. Good tip!
ChadKopplin
Thank you guys for your responses, this worked I was finally able to apply it.
