'Training loss' gets 'nan' when training deeplearning model
3582
10
08-04-2021 01:46 AM
梁飞王
hi all, I am trying to extract greenspace from the drone. but when I training the deep learning model, the  'Training loss' and validation loss returns  'nan', and the digram is blank. I tried to increase the label, using different types of models, but still the same.
I don't know which mistake I have made.  can anybody help me out?
by Anonymous User
Not applicable
@梁飞王 Can you share some more information about:
- Type of model
- Number of chips in training data
- Any noData in training data
Sandeep
MartyRyan
Sandeep,
I am having the same issue -
- Training a U-Net model
- "chips" in Training Data - not exactly sure what you mean, but here are my numbers; images (output from Export Training Data tool) = 2,199,856
- Training Data - I used a previously classified land cover dataset (on advice from an Esri rep) to export as Training Data - it has 15,512 polygons  - a portion of its attribute table is attached)
If these "nan" values are an error, along with the identical accuracy value for both epochs, how can I fix this while the model is still training? We are using a lot of time to run these tools, and need a useable result.
Thanks for your help
NOTE: I used the field LCCODE (which has values ) when exporting the training data - I'm having the sinking feeling that the "Name" and "Value" fields are the "No Data" items you are referring to? Am I resigned to stopping this model, calculating these fields to have values, exporting them again as training data and in effect starting all over?
MartyRyan
Sandeep,
I am having the same issue - any help is greatly appreciated.
Type of model: U-Net (pixel classification)
Chips in Training data - 2.199.856 images in Output folder (from Export Training Data tool)
Any noData in training data - not exactly clear on this but see attached documents for specifics. Thanks
What are my options while the tool is running, if any?
Thank you
by Anonymous User
Not applicable
Hi @MartyRyan
Can you share a sample of your training data ?
Sandeep
MartyRyan
Sandeep, I have solved my issue by adding and properly populating the clsname and clsvalue fields in my training data and also changing some of my input parameters. I don't know how they are related, but I have successfully trained a model with good results. The parameter settings I revised were:
  • Learning rate: blank
  • Parallel Processing: blank
  • Processing extent: default or set as my land cover extent
Thank you -
梁飞王
@Anonymous User
Thanks for your replay, here is the information
-I have tried kinds of models, mainly  FeatureClassifier\MaskRCNN, they all get nan when training model
-latest i tried : the images = 4885 *3*256*256
-I don't understand what is "noData", I made training data step by step on Arcgis Pro, label, and export. if there is noData in my data, I haven't learned to code so I can't eliminate them,
if there is noData in my data, does that means that my image is not intact or integral, that means my image exist some holes, but I get the training sample data by extracting from NDVI instead of draw.
Sometimes 'nan' may change to'0.0'  by adjusting Batch Size or Learning Rate, sometimes not, like this.
I am afraid I haven't made myself clear with my broken English. here is my training data exported from Arcgis pro.
https://1drv.ms/u/s!AuqSdRqzEo83uHlAIOsgSsMGTiBf?e=SrF8X7
王梁飞
by Anonymous User
Not applicable
Hi @梁飞王 ,
I am not able to access the sample data you uploaded.
Sandeep
梁飞王
yes,@Anonymous User
https://1drv.ms/u/s!AuqSdRqzEo83uHmo6JBfml1Zu2FJ?e=7fLk6b
thanks,
王梁飞
by Anonymous User
Not applicable
Hi @梁飞王 ,
I tried to the visualize the training data you shared it looks like this
there is only one class in the training data
Can you share a screenshot of your original data, are you trying to extract polygons of green spaces ?
The format of training data you have exported is not correct. You need to export the training data again in 'RCNN Masks' format. A similar workflow is documented here . However you can continue using the 'train deep learning model' tool, instead of using API as documented in this sample.
Sandeep
