Trace object
1437
12
11-29-2018 06:05 AM
IvanoGasco
New Contributor II
I have a polyline 3d feature which I want to trace to create some polygons.
Why the z coordinate is not traced (snapping is ON)? Is this not yet available?
Tags (1)
DanPatterson_Retired
It seems you have some steps
Create segments by tracing other features—ArcGIS Pro | ArcGIS Desktop
Specify an elevation for 3D features—ArcGIS Pro | ArcGIS Desktop
but I suspect for polygon output, you have the option of assigning 1 Z value
IvanoGasco
New Contributor II
I do not want to specify elevation. I would like it is fetched from the traced object, but it is set to 0.
By default, z-values are applied to new features in the following ways:
  • In maps, the default z-value is set to zero (0).
  • In scenes, z-values are derived from the active elevation surface when you click the scene.
IvanoGasco
New Contributor II
I do not agree. In maps, with Z-mode off and snapping on, the behaviour is as follows:
new features fetch the elevation (if available) from snapped feature
  • new features created with "trace selected features only" always set z to 0 even if traced features had z values <> from 0
by Anonymous User
Not applicable
Ivano,
As you suspected, this is not available yet in Pro. When tracing features with the elevation mode off, the resulting segment z values are 0. We'll work on it after 2.3
IvanoGasco
New Contributor II
This would be a great improvment in 3D editing.
IvanoGasco
New Contributor II
News about creating 3D polygons by tracing 3D polylines?
by Anonymous User
Not applicable
No progress for 2.4, still on the list.
AntonelloRizzo_Naudi
Hi Sean, I am working on ArcGIS Pro 2.5, and unfortunately the 'trace' tool is not maintaining the 'Z' values of the traced object.  Is this something with Pro or am I missing something. Thanks
