TopoToRaster - Invalid output extent - What's it looking for?
1211
07-10-2020 07:10 AM
by Anonymous User
Not applicable
I have absolutely no idea what this tool is looking for for an output extent. I have tried "default," "current map extent," and, the one I thought was bullet-proof - I entered the input contours.
It is rejecting everything I throw at it.
Would appreciate any advice anyone is able to offer.
Thank  you,
Randy McGregor
Tags (1)
DavidPike
MVP Notable Contributor
what's your output path? looks a bit dodgy
by Anonymous User
Not applicable
It's just an fgdb raster. That works fine. I think "default" will work for input extent, so seems good for now.
DanPatterson
MVP Esteemed Contributor
Are you using the tool in arctoolbox or are you using a model?
screen grab the toolbox tool inputs if you are using the former
... sort of retired...
by Anonymous User
Not applicable
Using it in a model. I changed it to "default" and it's working for now. That would be ideal. Earlier, I had not had good luck with "default" - It plugged 0,0,10,10 in for some reason. Fingers crossed.
DanPatterson
Randy McGregor‌ I will close this.  If you have further issues, you can reopen
