Tighten up space between each record in ArcGIS Pro Report
440
12-18-2019 12:29 PM
DanielWebb
I'm trying to figure out reporting in ArcGIS Pro.  I've got the "Basic Summary" template and select a few records in the table.  When exported to PDF, there is a lot of white space between each record. (Attached is an example screenshot)
Is there a way to tighten up those rows?
Thanks!
DanielWebb
So I figured it out.
In the report Contents, select the Details element.
In the ribbon, choose Format.  This tab has an option to set the Height.  This will set the height of each row of data.
DanielWebb
