The iterator of main model can only be iterated once in ArcGIS Pro2.8.3
1716
11
12-04-2021 07:40 PM
圈圈
I'm building a model and adding a submodel, both of which have an iterator.  When I run the model in Pro2.5, it is fine. But When I run the model in Pro2.8.3, I find that the iterator in the main model only runs once, and the iterator in the submodel runs fine.Is this a known bug about ArcGIS Pro2.8.3?
curtvprice
MVP Esteemed Contributor
Please do report it (and share the NIM in this thread so it will get voted up!) This sounds like a mission critical bug.
Doing this in Python is the obvious workaround. With the advantage of being able to do more parameter validation and error messages!
圈圈
Thank you for your advise.
