Text vs. Symbols vs Text Symbols vs. Graphic Text vs. Graphics
1028
01-01-2026 09:07 AM
Craig_Eissler_Iceman
Hello, I'd like to be clearer about the Terminology I keep reading about as I'm working with ArcGIS Pro and also attempting to relay things correctly to my students. For instance:
I understand there are several Text types, like Labels, Annotation, Graphic Text, and a few others. And, I understand the differences between these.
But what are Text Symbols ...Are all Text types Text Symbols? ...Even Graphic Text? ....or is there a difference between what is a Symbol and what is a Graphic?
CCE
VenkataKondepati
Honored Contributor
Great question. This confusion is very common, and it helps a lot to separate content from styling.
Short, clear way to explain it (and teach it):
  • Text Symbols are styles — they define how text looks (font, size, color, halo, background, callout, etc.).
  • Text types are things in the map — they define where the text comes from and how it behaves.
So:
  • Labels → dynamic text from attributes, styled by a text symbol
  • Annotation → stored features, styled by a text symbol
  • Graphic Text → manual text you place, styled by a text symbol
Yes. All text uses a Text Symbol, including Graphic Text.
The difference is behavior and storage, not appearance.
Symbol vs Graphic (simple rule):
  • A symbol = appearance (styling rules)
  • A graphic = a manually placed map element (which uses a symbol)
Text Symbols don’t exist on their own in the map — they’re reusable styling definitions applied to labels, annotation, and graphic text. This framing usually clicks quickly with students.
Regards,
Venkat
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
VenkataKondepati
Honored Contributor
So:
Regards,
Venkat
Hi Venkata,
Great explanation -- thank you!
