Table Help
131
a month ago
JulieAllsen
I am working on a hydric soils layout, and I have a table showing the MUSYM and MUNAME attributes of the soils present on each page of my map series. I cannot figure out how to have not have duplicates of attributes that are the same.  I've tried to look up what I can do to fix this, and I'm currently trying to "concatenate" using "summary statistics", but it is taking forever, and I'm wondering if there is a better/easier way.
Georgios-NektariosTselos
Hello @JulieAllsen , I suggest to you to try the following,
1.Use the "Dissolve" Tool  :
  • Navigate to Geoprocessing > Dissolve.
  • Set your input table or layer.
  • Choose MUSYM and MUNAME as the "Dissolve Fields".
  • This will remove duplicates and keep only one record for each unique MUSYM/MUNAME combination.
2. Alternative: "Delete Identical" Tool:
  • Go to Geoprocessing > Delete Identical (this is very fast).
  • Input your table or layer.
  • Set the fields to MUSYM and MUNAME.
  • It will delete all duplicate records with identical values in those fields.
Kind Regards
Nektarios
