Symbology Styles Not Available
671
07-28-2021 09:56 AM
Ske
Hi, My Arc Pro does not have any symbols styles available. When I try to add system styles the table is blank and does not give me the option to add anything.
Any help would be great, thanks!
Taren_Esri
Hi there,
Your best bet on this will be to run a repair of ArcGIS Pro. Go to your Control Panel, Add/remove programs, then select ArcGIS Pro, and Uninstall. From the menu provided, choose Repair, and go through the menus. This should fix the default styles.
Ske
Thanks for your response on this. I had already reinstalled the software on my PC and this rectified the issue but I will remember this for next time. Thank you!
