Symbology-Primary Symbology trouble
518
06-07-2024 08:38 PM
RileyWhitelaw
When I try to change the field for the symbology of my feature layer. All the values show up as the same symbol despite having it be graduated colors as my primary symbology.
This issue is also only affecting certain data in my attribute table.
I'd be thankful for any help
Robert_LeClair
Esri Esteemed Contributor
How many classes are defined for the graduated colors symbology?  Is it defaulting to 1 or 5?
RogerDunnGIS
As you know, a symbol in ArcGIS Pro can be layered.  Layers are added and removed in the Structure tab of the symbology (a wrench) and configured in the Layers tab of the symbology (2 3-D blue squares sandwiching a grey one).  Each symbol layer can have multiple attribute values assigned to it.  A layer can have have outline thickness and color, or be made from a font, or be made up of .png graphics, etc..  ArcGIS Pro's Graduated Colors paradigm has to be able to assign the property called "Color" in the various layers that make up the symbol.
With that said, my guess as to what you're experiencing, is that you're using symbols (and symbol layers) that either don't have a Color property, or you have layers with a Color property that are hidden behind other symbol layers without a Color.  I could be wrong; I'm only trying to help, but that's my guess as to what's happening.
