Symbology by Size of Aggregated Field
644
12-27-2024 02:06 PM
svector
Hi all, I learn GIS as I go and I'm usually able to figure things out eventually, but sometimes I'm missing the appropriate search terms. If I have a table like the one below and I want to symbolize budget range by dot size, where many records will fall into the same FIPS codes, how would I aggregate the budget total for each FIPS code. In the past, I did the work in the file prior to adding to ArcGIS but I'm wondering if there's a feature/tool that will easily do this or whether writing an expression would suffice (if so, extra thanks if anyone can get me started on that expression!) TIA!
objectID
Shape
st_abr
FIPS
budget
point
TX
48001
100
point
DC
11001
500
point
TX
48001
800
point
AZ
04001
250
point
AL
04001
300
6
point
TX
48001
980
7
point
CT
09001
850
8
point
AZ
04001
300
9
point
DC
11001
970
10
point
NH
33001
540
AmyHut
Are you wanting the sum of 'budget' from all points with same FIPS code? I'm sure there are other methods, but you can use the Dissolve tool, using FIPS as your Dissolve Field and the budget field as a Statistics Field and SUM selected as Statistic Type. This tool will create a new feature class with a field called SUM_budget which can then be used for symbology. There are a number of different statistic types to choose from (e.g. range) if another is a better fit for your question.
Staying tuned for any help with an expression too...
DanPatterson
MVP Esteemed Contributor
Summary Statistics (Analysis)—ArcGIS Pro | Documentation
with FIPS as the case field and Budget as the field to summarize
... sort of retired...
