Summarize Within running but not returning anything
7905
25
03-30-2021 11:48 AM
Miguel-Fernandez
I am trying to run the tool Summarize Within (Analysis tool) in ArcGIS Pro 2.7.2. The tool successfully runs but does not return a new layer or table. I can open the Details pane and see that the output locations are correct. But when I look in the project geodatabase, there is nothing there. The data I'm using for the input polygon is a single feature that covers several counties. The input summary features is a polygon layer of census tracts. I am trying to sum several of the attributes and use the group by function to group by county. Both data layers are in the same projection, epsg: 4269. I have been able to run other tools, buffer, intersect, etc and they all return the expected outputs. Has anyone else experienced something similar?
Miguel Fernandez
JayantaPoddar
MVP Esteemed Contributor
Could you share the screenshot of the parameters filled in Summarize Within tool, and the message dialog after the tool has run successfully?
Think Location
Miguel-Fernandez
@JayantaPoddar I've edited the post to include the screenshots.
Miguel Fernandez
JayantaPoddar
The parameters look fine to me. Refresh the output FGDB to check if the feature class is created. Else, close all the sessions of ArcGIS Pro, and open ArcGIS Pro.
Think Location
Miguel-Fernandez
@JayantaPoddar I have tried those steps and the issue still persists. I appreciate your suggestions.
Miguel Fernandez
JayantaPoddar
Would it be possible to share the input feature classes/ shapefiles ?
I would like to see if I can reproduce the same issue in my machine.
Think Location
Miguel-Fernandez
I'm having trouble getting the data down to size. I'm wrapping up things for the day here but I'll try again tomorrow. Thanks for all your help.
Miguel Fernandez
Mary_Murphy
What is the data type of the grouping field e.g. is it a text field or a numerical field?
Excelsior.
Miguel-Fernandez
@Mary_Murphy , the grouping field, 'County' is a text field.  I also tried running the tool without passing a field to the GroupBy argument and I'm still not getting any results.
Miguel Fernandez
Miguel-Fernandez
I also tried creating a new polygon feature class to act as my Input Polygon to summarize the Census data within and still the same results.
Miguel Fernandez
